After conversion, in some rare cases, the sound doesn't match the persons mouth movements. I am using the same settings as in other conversions. What could be wrong? Using TMPGnc.
This is an odd problem that seems to pop up from time to time (I've had it happen on two movies) Just go under forum search and type in 'fixing audio/video synch' and you'll find your answer. Luckily, it isn't too hard to fix
Good luck,
Macros -
Wow... and after reading that I though it looks like a pain to fix... I will try it though... looks like I gotta d/l a few other programs, and do some manual labor! Thanks.
tsmuxer problem with sound
By privateapples in forum Authoring (Blu-ray)Replies: 1Last Post: 8th Oct 2008, 02:53 -
no sound problem
By bountylord in forum Video ConversionReplies: 3Last Post: 26th Apr 2008, 18:37 -
problem with my HP sound
By arabian in forum ComputerReplies: 2Last Post: 27th Dec 2007, 03:51 -
Sound problem on PC
By greenpop in forum ComputerReplies: 2Last Post: 18th Oct 2007, 06:36 -
Problem with sound
By jarko in forum Newbie / General discussionsReplies: 6Last Post: 11th Aug 2007, 20:22
