my virtualdubmod couses the divx® 5.2.1 encoding settings screen to crash. is this normal, and is there another way to access the divx® 5.2.1 settings screen, i mean the encoding one, the one with all the options 1-pass, nth pass, quality, bitrate, and this stuff, not the decoding screen.
The crash occurs with vrtualdubmod when i go video->compression->select DivX 5.2.1 codec->configure ->settings (it is located low-left corner, next to restore to defaults)
10x
Did you install DivX before or after virtualdubmod?
Try uninstalling and reinstalling DivX.Google is your Friend
Wide screen (16:9) DV to Divx
By wayback in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 2Last Post: 4th Jul 2011, 15:05 -
How to view a divx movie full screen ?
By jedy in forum DVB / IPTVReplies: 4Last Post: 8th Apr 2009, 07:29 -
Dr. Divx Crashes
By GrayStrickland in forum Video ConversionReplies: 1Last Post: 1st Apr 2009, 12:43 -
Simple DivX: Crashes with Mencoder Error Every Time
By CobraPilot in forum DVD RippingReplies: 5Last Post: 10th Jul 2008, 20:47 -
fixed! Madden 08 on VISTA 32bit crashes after splash screen
By yoda313 in forum Off topicReplies: 9Last Post: 6th Oct 2007, 16:36
