Closed Thread
    Jan 2006
    Hello I am a newbie here and I am having problems with TMPGEnc Source Creator 2.0. I have looked at all the troubleshooting guides on the forum and I still get the problem which is when I try to convert a DVDRip file into VCD I get video but no sound and I have the latest codecs installed and everything and before I reformatted my pc I used to convert DVDRips or Xvid files with no problems, For example
    house of wax.2005.cd1.dvdrip.xvid.avi--When I try to convert that to VCD it does but with no sound and its only the dvdrips/xvid files so I only get video. is there any type of audio codec I need to install in order for me to get the video with sound? if so please help me out here and sorry if I am bothering anybody with this, Thanks much appreciate it.
    You are in breach of the forum rules and are being issued with a formal warning.
    / Moderator mats.hogberg
  2. ah-hem...
    you shoulddn't really give file names like that....
    but i guess you should of looked around... tmpeg don't like vbr mp3 audio you gotta find a prog that will save the audio as a wav file... like goldwave ...
    COOKIEEE!!!
    Jan 2006
    Sorry about the file name but its what I really got and I want to convert it to a VCD file but I get no sound and I dont want to have a seperate audio file because I am not going to burn it to DVD I want to convert to VCD, So are there any audio codecs for this?
    It would be easiest to convert from the original dvd if you are wanting best quality..
    ...you do have the original dvd right?????
    if you dont then you aren't going to get help here.
