I have a LiteON SOHW-1693S http://www.liteon.com/prod/getProduct.do?xml_id=4_2&menu_id=4_2_7&cid=1_7_13&pid=107 which I believe is a dual layer burner. I guess I need to know what software or burner program I need to do dual layer burns? I have RecordNow and RecordNow Max. Also I have a version of Nero that came with the burner.
Is there anything special or different than burning a single layer that I should be aware of? Finally what is a good brand of dual layer media to buy? Thanks for any help.![]()
You can do a search on this forum for 'dual layer burning' and get over 100 hits that should give you some good info.
The simplest program to use is DVD Decrypter, ISO read>ISO write.
Verbatim DL discs seem to work well for most burners. -
Hey thanks. I have DVD Decrypter however I didn't realize it was that simple to do a dual layer. I assume the burner knows when to switch layers? Anyway I shall pick up some Verbatim DL discs tomorrow and go for it.
check out >>>
https://forum.videohelp.com/viewtopic.php?p=1420924&highlight=copytodvd
The two programs I've use are .......
CopytoDVD with DVDFab Platinum (Express Mode) makes a 1:1 in an hour
and I used ... last night ... Sonic RecordNow Deluxe v7.21 ... took 2 hours to process and another 2 hours to verify.
and earlier today ... while I was taking care of some errands ... I started another copy/burning project and ETA time said 17 minutes ... how long did it really take ???
I don't know ... it was finished when I got home ... I was gone for about 4 hours at least.
I'm using Verbatim DVD+R DL ... right now $20 bucks for a 10 pack at Best Buy
Oh ... my burners are ... the PIONEER DVR-109 [mounted inside a USB external enclosure] and the Panasonic SW-9585S ... I also have the ...... Lite On SOHW-1693S but I haven't tried it to burn a DL disk.
Send me an PM and I'll let you in on a helpful tip -
One question. If I use DVD Decrypter in ISO mode will it create the VIDEO_TS folder and put all the filles in that folder?Originally Posted by redwudz
Doing dvddecrypter in ISO read will put only one file on your computer (the ISO Image,which is the entire dvd itself lumped into one neatly packaged product), no VideoTS folders.
What We Do In Life, Echoes In Eternity.... -
OK I bought two 10 packs of Verbatim 6X dual layer DVD+R discs today at BestBuy on sale for $20 per 10 pack. I used DVD decrypter in ISO mode and my fist burn is perfect. Thanks for the help.
Why I get a data disc every time when I burn BD-5 ?
By mahogany in forum Authoring (Blu-ray)Replies: 7Last Post: 6th Dec 2009, 04:10 -
cannot burn this disc
By m-man in forum MediaReplies: 6Last Post: 21st Apr 2008, 09:35 -
Cant burn on -dvdr disc
By dnst3 in forum Newbie / General discussionsReplies: 11Last Post: 20th Dec 2007, 02:46 -
after buring DL+R disc, my burn can't burn -R disc, please help!
By princejoe18 in forum DVD & Blu-ray WritersReplies: 1Last Post: 5th Sep 2007, 08:44 -
DVD to HD, Burn to Disc Later
By sucksjoe in forum Newbie / General discussionsReplies: 1Last Post: 14th Jun 2007, 01:30
