I am in a bit of a conundrum....I currently run a Hauppauge PVR-250 in my main system (fast) that I love. I am also building a low end HTPC which needs a capture card as well. A couple FSFT forums have Hauppauge Wintv Go Plus PCI cards for dirt cheap so the thought was use the PVR-250 in the slower HTPC rig and use the software based Go Plus in the fast rig. I'd want to test in the fast rig first though to make sure it meets my needs WITHOUT uninstalling the PVR-250 in case the Go Plus doesn't work out as well as I'd hoped.
Whew, so do you think there would be any problems having both these cards in one system? I am used to the WinTV2000 interface as well as the ease of TitanTV for scheduling recording. I have a number of preset capture profiles as well I use on a regular basis.
Any thoughts or comments would be appreciated
And before you ask...No I do not have the $$ to afford another PVR-250 or 150 at this time...if so this would be a moot post![]()
Originally Posted by Lcarvone
Avoid the false economy of the WinTv Go. Save up for another hardware encoding card.
Originally Posted by LcarvoneRecommends: Kiva.org - Loans that change lives.
http://www.kiva.org/about -
You maybe able to run WinTV2000 with both card install but you have disable one card in device manager in order for WinTV2000 to work one or other card depend which one you want run but keep in mind that WinTV2000 SoftPVR software I don't know anything about it and never test this type of setup.
Usb Capture Cards and Software Motion Detection
By glvid in forum Capturing and VCRReplies: 2Last Post: 6th Jan 2012, 08:44 -
Capture Artifacts - Hardware or Software?
By jday in forum Newbie / General discussionsReplies: 10Last Post: 10th Jul 2010, 10:08 -
Need Vista64bit capture hardware/software...
By nhgawe in forum Capturing and VCRReplies: 1Last Post: 19th Apr 2009, 16:26 -
Hardware or Software codecs for Starnet Development ad insertion system
By cybertheque in forum Capturing and VCRReplies: 3Last Post: 9th Mar 2009, 11:48 -
Capture Cards with hardware compression to Xvid/Divx?
By quantass in forum Capturing and VCRReplies: 7Last Post: 31st Aug 2008, 19:50
