I'm converting some .avi files to VCDs to play on the tv. It's been working fine, but now I've got some more files that don't work.
The problem is, VirtualDub says "No audio decompressor could be found to decompress the source audio format (source format tag: 0055)". However, it read other .avi files with the same audio format fine, and it still does read those fine. Format 0x55 is mp3, which shouldn't be a problem I thought, and AVIcodec shows the audio format of the readable and non-readable files as being exactly the same.
Both types of .avi file play in Videolan player, and show as using the exact same audio and video codecs. (audio = "mpga") Media Player can play the .avi files which VirtualDub can read, but it can't play the video of the ones VirtualDub can't read, and plays the audio with regular glitches every 2s or so.
Apart from what came with windows, I have DivX, Xvid and AC3 codecs installed.
Are my .avi files fuXXored? But Videolan can play them. Can anybody suggest what the problem might be?
try extract the audio to wav with goldwave,avi2wav. use the wav in virtualdub or the vcd encoder you are using.
or try our hidden forum search feature and search for 0055 for other tips. -
Correction... Quartz.dll is just a passthru. There's an actual filter called L3CodecX.ax where X is a letter. Beware that some of these are licensed MS versions, and some of these are hacked warez versions.
Yes, I was thinking of posting to ask if the forum has a search function...Originally Posted by Baldrick
Strangely, avi2wav produced a suspiciously small .wav output that didn't act like a .wav... then I looked on the avi2wav website:So it cheekily gives you the original audio format with whatever extension you ask for, hoping you won't notice. Ayayai...Originally Posted by agrgic.tripod.com/avi2wav/
Thanks for the tips - I'll try GoldWave now. -
demmit i thought i;d be smart and I used Goldwave to adjust for the diffrent audio and video streams length ... that was unnecessary. Do as Baldrick says:
1 open the avi in Goldwave,
2. save as WAV
3. merge the avi with the WAV in Vdub.
Apperently, you don't even need to Demux the video which would have resulted in a mute video.
With Vdub, it seems to overwrite the VBR audio with the WAV.
Set the Video on Direct processing (or else it takes 45 mins) and Audio on Full process and on a compression (or else you'd have a file comprised of 300 mb video and 450 mb audio.)
But i guess you already knew that.Looking for subtitles of: Höök tt0997023, Lime tt0269480, La clé sur la porte tt0077348. tt=iMDb.com Found Desideria tt0081724 subtitle! :-)
Audio suddenly drifting out of sync
By dubmunkey in forum Software PlayingReplies: 9Last Post: 13th Aug 2010, 08:46 -
Suddenly no audio with HDMI cable
By StarDweller in forum DVD & Blu-ray PlayersReplies: 15Last Post: 14th May 2010, 11:45 -
Getting Audio sync issues with handbrake suddenly...
By nodollas in forum Video ConversionReplies: 4Last Post: 30th Jan 2010, 06:44 -
Suddenly no sound playing back audio (MP3) on MySpace
By phaedrus in forum AudioReplies: 2Last Post: 26th Jun 2009, 20:13 -
cant SUDDENLY play all video files, only audio!
By dwardwarbinx in forum Software PlayingReplies: 6Last Post: 7th Jul 2008, 13:34
