I recently installed my PVR-350. I was going to go IVTV with a linux install, but yielded to Windows for my wife and her photography software.
Anyway, I've been really floored by cygwin and got most of what I need from it. I got it working last night, and I'll update this post as I get it more refined. To get this to work, install cygwin and the dvdauthor gui's on this forum. They give you the binaries mentioned in the script. I had to recomple mplex though... I'll see if I can't fix that. The cool thing about this it goes strait from mpg to vob without having to carve another 4 gigs out for each step.
==convert.cmd==
@echo off
bash convert.sh %*
==convert.sh==
#!/bin/bash
file=$1
mkfifo audio video mpeg
echo Starting audio with a delay to buffer fifo
mpeg2desc -a0 < $file > audio &
sleep 3
echo Starting video with a delay to buffer fifo
mpeg2desc -v0 < $file > video &
sleep 3
echo Starting mux to add NAV points to mpeg stream.
mplex -f 8 -o mpeg audio video &
sleep 3
echo Starting dvdauthor to write the fifos back to disk in VOB format
dvdauthor -o dvd_dir mpeg
rm $file
dvdauthor -T dvd_dir
echo All done!
To burn...
1) get the size by using 'mkisofs -print-size dvd_dir'
mkisofs -dvd-video dvd_dir | cdrecord-prodvd -dao dev=0,0,0 tsize=${size}s
rm -rf dvd_dir
Now if you want the mpeg back to make a compilation DVD (assuming your dvd is d: )
cat d:\\VIDEO_TS\\*.VOB > original.mpeg
The use of fifo's from a cygwin bash shell will also allow you to use this method with dvdauthor xml files. You just name the fifo as a file= in the xml.
Results 1 to 1 of 1
Dan <11011011>
mpg to vob conversion without re-encoding
By dalek6388 in forum Authoring (DVD)Replies: 4Last Post: 22nd Nov 2010, 16:04 -
problems with VOB to MPG conversion
By Created78 in forum Newbie / General discussionsReplies: 6Last Post: 21st Jul 2009, 12:20 -
Automated batch conversion to WMV?
By sparkin in forum Video ConversionReplies: 3Last Post: 3rd Jun 2009, 14:52 -
DVD/vob/mpeg to Avi/xvid automated process, Help!
By sinz in forum Video ConversionReplies: 0Last Post: 14th Apr 2009, 01:08 -
VOB to MPG Conversion: Can't get the right software!
By GeekyChocolate in forum Video ConversionReplies: 12Last Post: 5th Mar 2009, 23:52
