Asus A8N-VM CSM vs Asus A8N-E for Video Compression
I recently had a bad experience with a Asus P5WD2-P MB and have decided go AMD rather than Intel for this next attempt. Turns out the problem was probably not the fault of the MB, however in the process I learned about DRM problems some professional videographer friends were experiencing reading back their own authored DVD’s, and I simply don’t want to take that chance.
I’m currently looking at the above two MB’s and given what I learned on the forums concluded that I should seek advice BEFORE I purchase my next components. I intend to use an AMD Athlon 64 X2 4400+ and Corsair XMS 2GB (2 x 1GB) 184-pin DDR SDRAM DDR 400 (PC3200). I do not do gaming; I have an existing PCIe dual DVI video card that I will use; I may wish to do a little clocking adjustment, but not much (I never have in the past). I have read the forums for both of these MB’s, the reviews and user feedback. I will primarily use for ripping, editing, compressing, & authoring my own video. I would like 4 SATA-2 and 2 IDE. RAID optional. Given my intended purposes:
1. Is there a MB I should be looking at other than these two?
2. I see pros and cons to both the above MB’s.
a. A8N-VM CSM
i. pros: includes firewire, newer & better (?); chipset; better audio (?)
ii. cons: BIOS current limitations and instability; heat & cooling of processor and chipset
b. A8N-E
i. pros: more PCI and USB.
ii. cons: chipset fan noise
I would appreciate input from folks with experience using these boards. I have built over 100 systems, but it has been a four years since I have built a new system for myself, especially one for this specific need.
Results 1 to 1 of 1
--tim
video editing software on ASUS Eee PC
By helpmepls in forum LinuxReplies: 3Last Post: 10th Feb 2009, 06:51 -
By helpmepls in forum ComputerReplies: 2Last Post: 6th Feb 2009, 09:05 -
[color=blue]video oediting software for ASUS Eee PC (white ones)[/color]
By helpmepls in forum Newbie / General discussionsReplies: 1Last Post: 6th Feb 2009, 08:53 -
ASUS TV Tuner problem with Video in & audio adaptor
By Zpazt in forum Capturing and VCRReplies: 0Last Post: 16th Jul 2008, 15:30 -
DVD video burnig on asus rom
By tapal in forum Authoring (DVD)Replies: 0Last Post: 26th May 2008, 00:16
