Hi Ive got loads of movies in AVI format that i have downloaded from Grokster/Kazza etc that i would like to put onto VCD, ive just had a DVD player for christmas and i know it plays them.
Thing is i havent a clue how to do it, could someone please tell me step by step how to do this using Nero 5? and recomend me a program to covert the AVI into the correct format (Mpeg?).
Many thanks for reading any adfvice greatfully recd.
Avoid using Nero, download TMPGenc (see tools section) and refer to the following guide:-http://www.vcdhelp.com/tmpgenc.htm
Also download Virtualdub so that you can check what type of format each file is in.. Some of them are almost bound to be Divx, so once again you may need codecs (see tools section) to view them on your respective media player
<font size=-1>[ This Message was edited by: bilbogod on 2001-12-28 07:19:09 ]</font> -
Many thanks Bilbo-god i will check those programs out.
You say avoid using Nero though (running 5.5 not 5.0) is there any reason for not using it? if its not much good what do you recomend for burning, as movies all run fine on my computer i just want them to watch on my telly. -
I'm surprised to hear that recommendation about Nero. Many of us here at VCDhelp prefer NEro to any other burning program on the market. But, try a few and see what you like better.....
Macros -
Nothing worng with using Nero for burning (sorry for any confusion), I use it all the time. I was thinking more along the lines of its use in conversions... It doesn't seem too poular for this with other people on the forum
Ah yes, for conversions it sucks a large warty trolls ass (can you tell I've just seen Lord of the Rings?
But for burning I think it's tops.
Macros -
thanks again, so let em get this straight if i use TMPGenc to encode and NERO to burn then i should be ok?
Newby looking for help. With SONY PMB 64bit
By stewpot47 in forum Latest Video NewsReplies: 2Last Post: 15th Mar 2011, 07:16 -
Newby question. Nothing happens when I try a conversion
By ChicagoUser in forum ffmpegX general discussionReplies: 2Last Post: 12th Mar 2010, 16:28 -
M2TS to DVD Help-Newby
By Dano382 in forum Video ConversionReplies: 3Last Post: 12th Feb 2010, 16:30 -
Newby...importing dvd titles to pinnacle 12
By hurleyvcr in forum Newbie / General discussionsReplies: 2Last Post: 30th Dec 2009, 15:23 -
Newby Wanting To Copy Exercice DVD
By tommiefromva in forum Newbie / General discussionsReplies: 3Last Post: 25th Sep 2009, 20:59
