im trying to put subtitle to dvd (srt) but the format is 1/100 and it convert to HH:MM:SS:FF thats why it is out of sync.. is there any way i can convert first my original srt to maintain the right time when i use dvd-lab? thanks!
If it helps...
If the saved subs are off, in subtitle workshop you can open the text sub file, set timing on the left, maybe convert it by doing a save as & reopen (sometimes it's helped me), then play and adjust with video playback in subtitle workshop.
If it's the authoring prog that changes them, I think DVDLab Pro accepts a few different formats -- maybe try one of the others? If the subs are off a set amount, the sub dialog lets you shift all the subs forward or backwards.
For authoring software, the easiest in my opinion *for subs* is Sony's DVDA, starting with V. 2. Subs appear in a track above the video (& on video preview), and just drag to sync. -
According to the DVDLab Wiki, DVDLab does automatic conversions when it loads the time.
from http://dvdlab.wikicities.com/wiki/Subtitlestimecode such as 00:15:49:200 or 00:15:49:20 will be imported to DVD-lab as 00:15:49:06 for NTSC
So that's NOT your problem, unless the import is completely broken.
On the other hand, the SON format seems to have timecode in the way DVDLab prefers, and so far the only program I've seen that generates SON is MaestroSBT -
Which brings up a question... Is your DVD in PAL, or NTSC? and what frame rate did you set your Subtitles to? (yes, it DOES matter!)
Subtitle help with VLC and MPC using DVD and external subtitle
By enigmakid in forum SubtitleReplies: 2Last Post: 2nd Feb 2012, 01:48 -
DVD Lab Pro - Import .SSA subtitle problem
By satan999 in forum Authoring (DVD)Replies: 3Last Post: 27th Jan 2011, 08:21 -
DVD Lab Pro - New OS, same location of files = Subtitle generation = crash
By Paker in forum Authoring (DVD)Replies: 5Last Post: 18th Sep 2010, 09:56 -
DVD Lab message: No subtitle stream normal?
By stantheman1976 in forum Authoring (DVD)Replies: 1Last Post: 21st Feb 2008, 12:10 -
DVD Lab Pro Subtitle Mapping issues
By ArtOfLosingMFZB in forum Authoring (DVD)Replies: 1Last Post: 2nd Feb 2008, 21:41
