im getting this codec error (audio)
i used gsopt to check the codec
i tryed everthing to make a wave file but i cant seem to get the audio. do i need codecs? if so witch ones do i need? does this avi have audio?
Closed Thread
It's hard to tell from that. You should use the latest version of Gspot, 2.52.
You can also use a program like DXMan or Codec Sniper to get more info about your codecs and remove them if needed.
It has mp3 audio and Windows comes with an ACM mp3 decompressor.
If all you want to do is decompress to a wav, you could try something else like mplayer.
But one thing I saw was that VDub does NOT like to read VBR files, and you got a VBR audio stream there.
Originally Posted by kschangIf in doubt, Google it.
the avi is lost S2E3 and im trying to convert it into dvd. i tryed "dircet stream copy" to get the audio, but when i convert the avi with the dircet stream copy wav. the voices are all off (very bad)
ive tryed everything, but i cant get the audioheres some more info about the avi maybe some will see something i missed, so i could get the audio
You are in breach of the forum rules and are being issued with a formal warning. Buy Lost here when it comes out:
http://www.amazon.com/exec/obidos/tg/detail/-/B00005JNOG/qid=1136930231/br=1-1/ref=br_...dvd&n=14068831
/ Moderator Cobra
No warez.
Please re-read the Forum AUP here:
https://forum.videohelp.com/viewtopic.php?t=124514
VirtualDub Error Message - Video Compression Error
By HartsVideo in forum DVD RippingReplies: 19Last Post: 7th Jun 2009, 20:18 -
Error with Xvid4PSP when converting MKV to AVI (VirtualDub Error)
By Peter25 in forum Newbie / General discussionsReplies: 1Last Post: 9th Apr 2009, 18:10 -
Virtualdub Error
By Hittz in forum Newbie / General discussionsReplies: 3Last Post: 3rd Nov 2008, 08:27 -
VirtualDub error
By WebMaximus in forum Newbie / General discussionsReplies: 22Last Post: 6th Aug 2008, 01:55 -
VirtualDub error
By srikat in forum Newbie / General discussionsReplies: 1Last Post: 24th Aug 2007, 03:40
