how can i create chapters in an raw mpeg2 file. The reason i ask is because my video player plays mpeg files, and if i have a movie that is 2 hours, i have 2 hold the forward scan button for a long time. It would b good if i can add chapter marks so i can use the skip button.
only if you'll create a proper CVD or SVCD image (using i.e. free VCDEasy as kschang mentioned). If you don't want to burn such image to CD, you can then use any of the popular image-mounting-tools/apps to mount the image from your hard disk (or burn the image as files on DVD-R and mount it from there).
Other than that there is no alternative to FF/REW with plain MPEG or AVI files...
EDIT: some standalones are able to create its own "menu" of the files contained on a disc. It works like chaptering the file with automatic screenshot creation, similar to displaying the content of picture discs, and navigation is as easy. Check out the options of your dvd player, perhaps you have it. -
...but to answer your question: No, raw mpg can't have chapters.
/Mats
Editing the chapter marks in a dvd ifo file
By jjulio1 in forum DVD RippingReplies: 1Last Post: 5th Aug 2010, 06:03 -
Problem with transitions/chapter marks using Nero 7
By dvdtcb in forum Newbie / General discussionsReplies: 0Last Post: 17th Jan 2009, 12:58 -
Re: getting interactive chapter marks windvd creator 2
By tomcat862 in forum Newbie / General discussionsReplies: 1Last Post: 28th Feb 2008, 14:38 -
Newbie needs help with chapter marks on Lite-On unit
By Learnin to Burn in forum DVD & Blu-ray RecordersReplies: 5Last Post: 20th Nov 2007, 12:25 -
I would like to insert chapter marks and possibly a menu
By the six-teens in forum Authoring (DVD)Replies: 3Last Post: 9th Jul 2007, 21:09
