I have been using Netscape since day one and have now decided to start using Firefox.
2 questions....
Is there a way to set up different profiles with Firefox for different users....for different bookmarks and other options.
Is there any kind of mail feature with this program like Netscape? If not what do you use for email?
Thanks for any help.
No mail feature inside Firefox but there is a mail client made by them called Thunderbird.
if you use different logins under XP/2000 then each user will get a seperate profile created under their login.
If you are using a single login for all user then you can use the progile manager to set up and manage multiple profiles. Start your reading here http://www.mozilla.org/support/firefox/faq.html#profilemanagerRead my blog here.
Thanks, guns1linger....that was simple enough....although a bit odd I had to use the run command to do it!
Now to check out Thunderbird that Faustus suggested and I'm all set!
Thanks guys,
Hutt
What is best for web broswer(New PC W7)
By newworldman in forum ComputerReplies: 12Last Post: 1st Mar 2010, 23:15 -
Firefox questions
By WinSpecToR in forum ComputerReplies: 6Last Post: 26th May 2008, 12:43 -
a couple of sub questions
By Kanyeeeze in forum SubtitleReplies: 1Last Post: 1st May 2008, 18:03 -
a couple of questions ..
By ZaYoOoD in forum AudioReplies: 6Last Post: 7th Mar 2008, 15:21 -
couple questions
By mainegate in forum ffmpegX general discussionReplies: 2Last Post: 31st Aug 2007, 12:22
