I'm converting a XviD file I have using Nero Vision 7.0.1.4, the bitrate of the video on the XviD is 1182. When converting it to DVD, should I keep the bitrate the same? Or go higher?
I can go as high as 4250, which will max out the DVD disc.
Thanks.
The bitrate required for an mpeg is far higher than for a similar Divx or Xvid. I recommend that you max out the disk.
"Art is making something out of nothing and selling it." - Frank Zappa -
It also depends, to a degree, on the method and matrix the endoer uses. Some can produce OK results at lower bitrates. Some really struggle. As a general rule though, mpeg2 requires around 3 - 4 times the bitrate as mpeg4 (xvid/divx) to maintain comparable quality.
You should also be aware that the resizing up process will enhance any flaws in the original avi file (and believe me, they are there, even if you believe you can see them now). If you want to address these issues before encoding, I would suggest avisynth and a real encoder, rather than letting Nerovision do it for you.Read my blog here.
tv player at reasonable price that can play hi bitrate xvid/avi?
By extent in forum Newbie / General discussionsReplies: 0Last Post: 25th Feb 2010, 08:42 -
AVI to DVD fourCC xvid question
By rockonvidtrade in forum Authoring (DVD)Replies: 7Last Post: 23rd Feb 2009, 11:29 -
How to reduce resolution and video bitrate in XviD AVI files?
By hibbs in forum Video ConversionReplies: 2Last Post: 13th Jan 2009, 11:50 -
Bitrate question for Avi to Wmv conversion w/ Windows Media Encoder
By Gonz0ne in forum Video ConversionReplies: 5Last Post: 6th Jan 2008, 08:19 -
Resizing AVI and changing bitrate using Virtualdub and XviD
By mlwitchking in forum EditingReplies: 7Last Post: 27th May 2007, 14:45
