Results 1 to 10 of 10
  1. I love media player classic but I have a huge issue whenever i play anytype of file with it. If i have the volume up halfway on the player, and i fastforward 10seconds or 10 mintues, the sound jumps to 100% out of the speakers (the bar doesnt actually move) Also, when I got to fullscreen the audio goes to full...No other players have this problem for me, but I would perfer to use classic. Any ideas? Thanks
  2. Member waheed's Avatar
    Jul 2003
    Manchester, UK
    I have exactly the same problem. Maybe it could be a bug in MPC. If someone can provide a solution, it would be great.
    are you using the latest version? or maybe try some older version.
  4. yeah I have the latest version (6.4.8.7) I am very puzzled
  5. Same problem here.
  6. so does no one have a fix for this...?
  7. Go back to an earlier version. In addition to the odd behavior others have seen, I had trouble with file associations, icons, and settings that wouldn't "stick". Currently using 6.4.8.4, and will wait for the next release.
    Pull! Bang! Darn!
  8. Member waheed's Avatar
    Jul 2003
    Manchester, UK
    Im using version 6.4.8.2 which is an earlier version.
  9. Originally Posted by waheed
    Sorry, I meant the guys using 6.4.8.7. Worth a try. Isn't that odd that you have the same problem with an earlier version? Fresh out of ideas here. :P
    Pull! Bang! Darn!
  10. Member waheed's Avatar
    Jul 2003
    Manchester, UK
    Ive just put it down to being a bug in MPC. It doesn't happen with any of the other players.
