I have 2 avi files with different audio sampling rate, 32000 Hz and 48000 Hz.
If i try to merge the files with nandub then I get next error:
avi files have not the same audio sampling rate.
On which manner can I make both avi files working at the same sampling rate ?
https://forum.videohelp.com/viewtopic.php?p=1437011#1437011 or similialrialr. both must have exact same audio settings. under audio->sampling rate chnage to 48 and save and then join it with the other clip.use also video->direct stream copy.
How to merge avi files?
By mkvelidadon in forum Newbie / General discussionsReplies: 3Last Post: 26th Sep 2011, 03:25 -
merge mov files?
By Boru in forum MacReplies: 8Last Post: 30th Apr 2010, 00:43 -
merge two avi files
By Jorge in forum Video ConversionReplies: 4Last Post: 17th Feb 2010, 23:01 -
Combine/Merge two avi files
By motherwell in forum MacReplies: 4Last Post: 28th Jan 2010, 16:45 -
How do I merge 2 .avi files? (using which software)
By Hank Kinsley in forum Newbie / General discussionsReplies: 3Last Post: 9th Jul 2007, 00:46
