I recently got a PSP for myself for christmas and I can't seem to get the encoding to work properly. I am encoding from .avi files which were previously encoded to XVID, AC3(passthrough). Because most of my movies are in 2:35:1 aspect ratio I am selected the present PSP mode then adjusting the size to 368 x 160 with 24 padding on the top and bottom. Thus far I have not been able to get anything to play on the PSP. When I try to play the movie I get invalid format error. Is there any trick I should be looking into? Thanks for the help. And by the way my PSP has the latest firmware upgrade installed if that matters.
I guess that 368x160 is unsupported by the PSP. Try 368x208 and check http://homepage.mac.com/major4/psp.html
Major I got it working. The 368 x120 works fine as long as you have the padding setup right for it. For some reason the particular movie I was trying to work with was having problems. I tried a different movie and had 0 problems. Should have checked that before I posted. My apologies.
PSP encoding woes - chipmunks overruning the audio
By Cyntalan in forum Video ConversionReplies: 0Last Post: 27th Jan 2011, 20:48 -
Encoding iPod/mobile + PSP AVC compatible files.
By x2x3x2 in forum Video ConversionReplies: 2Last Post: 11th Sep 2009, 02:42 -
Encoding for the PSP
By Suzuka in forum ffmpegX general discussionReplies: 2Last Post: 30th Sep 2008, 15:01 -
PSP encoding error
By richgone in forum ffmpegX general discussionReplies: 2Last Post: 14th Feb 2008, 07:06 -
Method for encoding Motion JPEG for PSP
By ByteMe72 in forum ffmpegX general discussionReplies: 6Last Post: 13th Nov 2007, 17:02
