    Jan 2005
    when i do the ctrl alt del a window with 6 options comes up : log off, task manager, shut down, lock comp... but i just want my task manager to pop up how can i do this? thnx
  2. Banned
    Feb 2005
    USA
    Looking at your profile and your post here I don't see which OS you are using. Is it linux? BeOS? Mac OSx? Win95? Win3.1? WinXP? Win2K? Other?? There are many different options and unfortunately any response without this information being provided may not help you.
  3. Greetings Supreme2k's Avatar
    Feb 2003
    Right Here, Right Now
    Uh, ctrl-alt-delete to Task Manager? Windows (32-bit). 3.1, BeOS, Mac, linux don't have it. He was pretty distinct.
    Anyway...
    To start (just) Task Manager
    Press CTRL+SHIFT+ESC.
    or
    Right-click an empty area of the taskbar, and then click Task Manager.
    I forgot the exact settings to get straight from ctrl-alt-del, but I'll post if I find them.
    Apr 2004
    Miskatonic U
    You are on a domain, aren't you ?
    If you are, policies will probably stop you changing anything anyway, but personally, I wouldn't screw with it. Just create a new hotkey for it and live with it.
    If not, try this http://support.microsoft.com/default.aspx?scid=kb;en-us;308226&sd=tech
    Read my blog here.
