    Dec 2002
    How can i get DVDSHRINK extract the DTS track as well as the 5.1 and normal tracks of a DVD. I only want to take one chapter of a DVD but the dts track doesnt seem to? any ideas
  2. Use IfoEdit or PowerDVD to check what audio was ripped.
    If DVDShrink doesn't work you could try DVDDecrypter->IFO Mode and select the chapter.
  3. Member yoda313's Avatar
    Jun 2004
    The Animus
    The way to double check is in the reauthor mode select the "compression settings" tab. There you should be to verify that both soundtracks are highlighted and then continue ripping the chapter out.
