    Dec 2005
    Hi, I ripped a dvd karaoke song with dvd decrypter and the vob file should have 2 audio streams in it. I tried to make a karaoke dvd with menus, when I burned the song and played it in my dvd player. Somehow there is only one audio stream playing. I tried to press the "Audio" button on the remote controller and it should switch to the audio stream 2, which is nonvocal, but it didn't do that. Do you know any DVD Authoring software that can burn "vob" file with 2 audio streams and play with a dvd player with 2 audio stream switchable?
    Thanks!!!
    Nov 2005
    AFAIK a karaoke DVD is different then a normal one -- might need special procedures -- so couldn't hurt to search for guides.
    As far as 2 audio streams, more expensive apps offer it, possibly one of the freeware DVDauthor GUIs, & there are methods of adding the 2nd track into your authored DVD.
