  1. Hi all nice to meet you hope you can help me with this problem
    I just bought Titanic 2 dvd version whihc i did not know ahhhhhh
    so i tried to merge the dvds together i am going to write it back to a 1 dual layer dvd.
    now after about 1 hour i got the dvd to go stright to the main menu missing all that crap out at the start of the dvd (thank god about 2 mins of rubbish)
    now here is the problem when i play the dvd it works all the way to the end of dvd 1 and then asks to insert dvd 2 and then stays like that for 1 min then gos back to the main menu instead of playing dvd 2
    so the problem is how do i get the last chapter of dvd 1 to go to the first chapter of dvd2 so there is no stoping or gaps in the dvd ???? i just dont know what i am doing to get this right i hope you can help thanks
    using dvdremake pro
    all
    have a good one
    Nov 2005
    Don't know how much help this will be -- don't use remake pro...
    Basically a dvd is all video files, and there are instructions in the ifo files about what to do next whenever one ends, finishes playing. You're is set to the menu, which leads to the main menu apparently. You just have to change the directions telling it what to do, and for that sort of thing pgcedit excells, though it does have a learning curve so you'll want to read guides etc.
