I'm trying to take a small segment from DVD and put in on my computer in mpeg format. This seems like it should be easy but I'm not sure which program to use.
I have Nero, TMGDVDauthoring, and TMGexpress.
Thanks for any help.
this is no advanced conversion. moving you.
read https://www.videohelp.com/guides.php?guideid=638&howtoselect=3;6#638 -
Thanks but I already did that before bothering you.
I used DVD authoring and it created a Volume 1 file with a video TS file that contatined VOB files. The guide said it would conver to mpeg.
That is why I sought help. -
FWIW, generally want to 1st get access to the material, following guides on how to do that.
2) want to extract a section of video. Again several guides, &/or recode will do it for you under authoring.
3) want to extract the video from that, again following any of several guides, perhaps using something like pgcdemux or rejig or...
4) now you have 1 video and 1 (+) audio files in mpeg2 & probably ac3 (for audio). Follow guides to turn them into whatever format you'd like.
want to capture directly to ffdshow mpeg-1 or mpeg-2 for dvd
By wolfdogg in forum Capturing and VCRReplies: 10Last Post: 10th Jan 2012, 08:23 -
DVD to an edited MPEG-2 file with MPEG audio: Trouble/please help
By Canon GL-2 Guy in forum Newbie / General discussionsReplies: 21Last Post: 9th Aug 2011, 09:52 -
MPEG II to MPEG (DVD): Transcode or reencode?
By Jeroen1000 in forum Video ConversionReplies: 8Last Post: 12th Feb 2009, 18:44 -
MPEG-1 to MPEG-2 to DVD Advantages/Disadvantages?
By louv68 in forum Video ConversionReplies: 4Last Post: 7th Jul 2007, 17:51
