Is there anyway to convert multiple files to Dvix/Xvid on Virtual Dub?
yes, you can batch encode (at least with virtualdubmod, i'm pretty sure its done roughly the same way in regular virtualdub though....) just open the file, set whatever compression you want, then go to save file...and wherever your going to set your output, there should be a little box you can check to add a file to the batch....just check that, then whenever you got all your files set up, go file>job control and click the start button and thats about all there is to it....
Virtual dub
By santolina in forum Newbie / General discussionsReplies: 4Last Post: 22nd Jul 2009, 13:48 -
Virtual Dub Conversion Question
By zenzen1 in forum Video ConversionReplies: 14Last Post: 11th Apr 2009, 09:15 -
help with virtual dub
By Remyisme in forum Newbie / General discussionsReplies: 7Last Post: 30th Jan 2008, 15:36 -
Virtual Dub in asp
By dizzy123 in forum ProgrammingReplies: 13Last Post: 19th Sep 2007, 06:00 -
Virtual Dub Mod
By OG24 in forum Newbie / General discussionsReplies: 11Last Post: 8th Aug 2007, 15:36
