I did a forum search and couldn't find what I was looking for. feel free to link me to the appropriate thread if necessary.
anyway, I have the philips dvp 642/37 player with the 0531 firmware but I've yet to hack my system. my main questions about this player are:
-is the 7-8-9-OK-0 hack a one time hack that I don't have to worry about? or do I have to continuously apply the hack everytime I want to watch a R2 disc?
-i'm assuming the NTSC to PAL conversion is automatic correct? once the system has been hacked I'm supposed to go into the system menu and select NTSC right?
-i'm assuming the newer dvp 642 models (in the white box) still use the 7-8-9-OK-0 hack and only have different firmware correct? i'm wondering if I should buy myself a backup system just in case - they're only $60.
Results 1 to 13 of 13
Yes, the hack for region free is one time only. You can even change back to the original region should wish, then change back to region free. For NTSC/Pal you just set the player to the same as your tv and then it automatically converts. I am not sure about the newer models, mine is about one year old. I do not see any reason why it would not work. As for a back up, there are always newer models coming out, so replacing it shouldn't be a problem. My vote would be to wait.
well, I tried the 7-8-9-OK-0 hack and I think it worked. I saw the '0' at the bottom of the tv screen so i'm assuming my player is now region free. I won't know for sure until I get my R2 discs in the mail.
another question, i've downloaded a few things that are in avi format, is there a way to convert them to mpegs or divx formats so that I can burn them to disc and watch them on my dvd player? i've used DivX doctor II.1 to convert avi files to quicktime files, at least I think they're quicktime files - once they're converted there'es an "m 1" tag appended to the end of the file but i'm able to watch them in quicktime. i'm also on a mac - is there any free software conversion software available?
thanks, handyguy.
btw, do any of you ever have problems playing region 2 discs from asia? i'm wondering if it's just my player. -
I dont have any asia disks tho. What happens when you play it?
Sometimes playing other region disks the picture looks weirdo but pushing system menu button 2 times corrects this. -
...I have this dvd and is great...is there a way i can change the
background pic or screen saver to something else. -
Originally Posted by handyguy
i'm still waiting for my R2 discs to arrive from the UK, this was I can test my player and see if they experience the same glitches as the R2 disc from Asia. -
More likely than not, you're unit is overheating. Pay special attention not to put anything over or under it (e.g. cable box, VCR, etc.). Give it lots of breathing room and it should play okay.
Originally Posted by giannid
Philips DVP-642 16:9 Display
By wulf109 in forum DVD & Blu-ray WritersReplies: 4Last Post: 27th Jan 2010, 12:39 -
Philips dvp 642 help?
By imemine in forum DVD & Blu-ray PlayersReplies: 7Last Post: 3rd Feb 2009, 02:22 -
Philips DVP 5140 or DVP 642/37, which is better?
By Amuse in forum DVD & Blu-ray PlayersReplies: 2Last Post: 2nd Feb 2008, 16:26 -
Philips DVP 642 (37A) dvd player -does it play PAL
By Katiemay in forum DVD & Blu-ray PlayersReplies: 8Last Post: 11th Jun 2007, 23:16 -
Philips DVP-642 and x.264 HD encoding
By dfishman923 in forum Newbie / General discussionsReplies: 2Last Post: 13th May 2007, 14:36
