Used DVI>VGA adapter supplied with videocard to connect monitor.
Got no signal at all.
I've seen other people's posts in other forums with the same problem, so it's not solely
To prevent further questions,this is WHY I want to connect monitor that way:
My Plasma TV (Pan. 42PA50E) has no DVI or VGA inputs
My LCD monitor (LG1730S) has no DVI input, only VGA
My videocard (GF6800GT) has DVI, VGA, & SVHS outs.
I need VGA out to connect my plasma tv using VGA>component transcoder, so, I can use only DVI to connect monitor
Please, help me solve this mystery, I want to use this card and monitor in the future and not planning to change it.
Could you change your title to something that decribes your problem, please? You'll get many more reponses that way, and it helps those who are searching for this solution in the future. You can edit it by pressing the "Edit" button on your original post (remember to log in first).
Many thanks,
Cobra
Forum Moderator
Can I interface my VGA monitor through a HDMI-DVI-D cable via DVI-D to VGA?
By vinny88 in forum Authoring (DVD)Replies: 4Last Post: 14th Oct 2011, 09:31 -
DVi to VGA adapter for acer lcd question
By Denvers Dawgs in forum ComputerReplies: 4Last Post: 2nd Feb 2011, 14:24 -
Plug DVI/HDMI adapter to DVI video card?
By Stealth3si in forum Media Center PC / MediaCentersReplies: 25Last Post: 23rd Dec 2010, 20:32 -
USB to DVI Video Adapter?
By lenny_67 in forum Media Center PC / MediaCentersReplies: 0Last Post: 19th Mar 2010, 12:24 -
Using a DVI to Component adapter?
By videonewbie69 in forum DVB / IPTVReplies: 15Last Post: 2nd Aug 2007, 06:17
