    Jan 2006
    I'm trying to convert a WMV file to an MP4 file w/ H.264 encoding with SUPER v2006.build.13. However, while the conversion executes properly, the converted file has a watermark in the bottom right corner with seemingly my Windows login name.
    Any idea what's going on? Thanks for the help.
    Jan 2006
    Bump! Thanks!
  3. Member lantern's Avatar
    Oct 2003
    Behind the dark matter
    From the SUPER support forum:
    The username watermark option can be disabled by unchecking "Use DirectShow". A future release will add an option to enable/disable it.
    There was also mention of a "fix" for this in the next version.
    Melde Melda Vessė
    Eruanna ar Eruntano Melda Eruntanohini
    "May your days be bright and contact with stupid people limited."
    Jan 2006
    Thanks. Unfortunately, when I made that change I wound up with just a black screen for my output file. Is there any chance you could provide me with the link to the SUPER support forum please?
