Results 1 to 13 of 13
    NYC
    Hello People,
    Happy New Year!
    I wish you all the Best!
    I am pretty sure it was probably discussed here before...
    I found these so called "center hole" CD/DVD Hub Labels:
    http://www.surething.com/ST/Product.asp?ProdCode=20006
    I think its a nice alternative to screwy regular labels (especially for DVDs).
    What do you think?
    Have you had any experience with this type of labels?
    Are they reliable?
    I really need your input,
    TIA
    taboo
  2. I use the Neato hub labels all the time. Haven't noticed any problems. Full size labels are another story...
    Pull! Bang! Darn!
  3. Member dutchdummy's Avatar
    Nov 2005
    Southern CA, U.S.
    Originally Posted by taboo
    Hello People,
    Happy New Year!
    What do you think?
    Are they reliable?
    TIA
    taboo
    I've been using Neato's hub labels for a while now and have had no problems whatsoever. When I first started burning DVDs, I tried to use full labels, but they made some of my discs unplayable. After I switched to the hub labels, the problem disappeared.
    I now own an Epson R200 printer, so I'm currently phasing out the hub labels in favor of printable DVD+Rs, but I would recommend the hub labels as a good alternative.
    Bob
    NYC
    hey fritzi93,
    I love Neato myself.
    I ve been searching their web site but could not find it.
    Maybe you can send me a link, please?
    TIA
    taboo
  5. Member dutchdummy's Avatar
    Nov 2005
    Southern CA, U.S.
    You can buy them at http://www.neato.com/neato_prodtest_sub.asp?class%5Fid=%5FPHOTOMATTE&cat=%5FCDLABEL&ms...HSKGDSJPPQ3GUC . You'll find them listed as 'Core labels'.
    Bob
    NYC
    Bob
    thanks Bob,
    thats exactly what I am trying to do.
    Any suggestions on brand? Urls?
    TIA
    taboo
  7. Heh, beat me to it. :P
    Pull! Bang! Darn!
    NYC
    Awesome!
    Thanks a lot all!
    NYC
    Hello People,
    I got my labels today. They are really cute.
    I ve been using my own layouts created in Photoshop for both of my NEATO trayliners and CD labels.
    What software would you recommend to use for them?
    Is there any easier way of doing it?
    Also, how you apply those labels to disc?
    I usually did it by hands
    Are you using so called CD Labeling kit?
    Is it any good?
    TIA
    taboo
  10. Member wwaag's Avatar
    Jan 2002
    Olympic Peninsula, US
    I use Neato's MediaFACE 4.01. It's got a template for their hub labels (20 labels per page). Only drawback I've found is that you can only design and print 1 label at a time.
    wwaag
    NYC
    yeah, I got it
    let me try it. I will let you know
    thanks,
    taboo
    NYC
    hey wwaag,
    You're right about MediaFACE 4.01. Its totally inconvenient to print labels with it.
    Instead I use PhotoShop 7. I am already using it to create my trayliners and cd labels and it does amazing work.
    What I did is I scanned Neato template, put layer with circles above cut-outs, hide layer with scanned template, aligned circles with cut-outs by test printing.
    As for text, you would need type text and then use WARP TEXT feature with ARC style either Horisontal or vertical.
    Hope this will help,
    taboo
    PS. Btw, what information are you displaying on your labels? Anything else besides YEAR and TITLE?
  13. Member wwaag's Avatar
    Jan 2002
    taboo,
    Good idea about scanning the template into photoshop. Will probably stick with MediaFace since, at this point, since I only do a label or 2 at a time.
    For movies, I only print title and year.
    All in all, I like these little hub labels. Maybe not as "pretty" as a printed DVD, but certainly a lot more convenient and cheaper.
    wwaag
