    Aug 2005
    Atlanta, GA
    Are there possibly any blank dual layer DVD-RWs on the market? If not, is there any kind of DVD copying software that can split up a 7.5GB disc and be able to put it on two regular DVDs?
  2. [url=http]text[/url] Denvers Dawgs's Avatar
    Feb 2003
    Right Behind You. . .
    There are only if the files are from from a dvd.
    Originally Posted by Vejita-sama
    Spilt to two DVDR discs (no lost in quaility)
    There are lots of programs that can do option that. Freeware wise IFOEdit and DVDFab are popular. DVDFab is no longer freeware but previous freeware verisons are stll floating around here and at http://www.doom9.org
    Originally Posted by IAmNotAPirate
    Use DVDFab to split the DVD into two. There is a great tutorial listed on HERE
    This only took me about 10mins to find what you needed. Try using the tools section are doing a little research ahead of time.....
    What We Do In Life, Echoes In Eternity....
    DVD-R DL
    DVD+R DL
    No RW DL
    Split for SL DVD-RW, DVD+RW ? Sure, plenty.
    Go look in the TOOLS section, lots of options.
