    May 2005
    Canada
    I bought a Sony DVD player long time ago. This DVD is known to read original dvd disc only, none of copied disc can be played.
    Surprisingly, it plays DVD-R disc for more than 6 months. Now the player suddenly could not read any dvd disc, even the original one (got message No Disc). Does anybody know why and how could I fix it .... before I throw it away ? Thanks
    Andy
  2. Aging Slowly Bodyslide's Avatar
    Feb 2002
    A Different Timeline
    Try using a DVD cleaner in it. It could just be a dirty laser. You can buy one for less than 15.00 or so....
  3. Member yoda313's Avatar
    Jun 2004
    The Animus
    Actually these days you can buy a cheap cyberhome dvd player for under $50 that will probably have more features then your old sony. Might be time to upgrade. (there are other inexprensive brands beside cyberhome as well).
  4. Disgustipated TooLFooL's Avatar
    Feb 2004
    Opium Den
    reason why is because sony dvd players come with a 6 month warranty. how to fix it, call sony and bend over.
    I am just a worthless liar,
    I am just an imbecil
