Hi! Ive been trying to encode some of my vob files into AVI format using DIVX. How come the max bitrate im allowed is either 4000 or 4854? I am using the newest version of DIVX, but I believe when I used older versions it didnt set a limit! Please help!
Are you using one of the profiles?? You may have it set to one of the portable video formats which limits your resolution options.
Try setting it to "home theater" profile and you should be able to use a higher bitrate. If your destination is just the computer and not a DIVX enabled dvd player set it to "UNDEFINED" and you'll be able to change all the settings you'll need.Donatello - The Shredder? Michelangelo - Maybe all that hardware is for making coleslaw?
Finding out the peak bitrate of a DivX file
By Anakin in forum Video ConversionReplies: 2Last Post: 8th Oct 2011, 15:25 -
Any way to set default DivX bitrate in AutoGK ?
By spidey in forum Video ConversionReplies: 2Last Post: 17th Jul 2008, 01:11 -
Divx 6.8: bitrate vs target quantizer?
By peggypwr1 in forum Video ConversionReplies: 1Last Post: 5th Feb 2008, 21:35 -
Lower video bitrate for a DIVX movie?
By DonGallego28 in forum Video ConversionReplies: 2Last Post: 10th Jan 2008, 19:09 -
Trouble Finding Bitrate for DivX Xvid for CD-r
By 4194 in forum DVD RippingReplies: 9Last Post: 24th Aug 2007, 10:41
