what programme can be used to edit/cut a movie in wmv.format?
<---Tools section
https://www.videohelp.com/tools?s=108#108What We Do In Life, Echoes In Eternity.... -
might also want to check some of the utilities microsoft offers. IF the format matches a preset profile in movie maker, using movie maker it's supposed to be possible to edit & only have changes recompressed. There seem to be a lot of media center fans/users, and I believe I've seen some new tools for wmv and similar - might want to check those fan sites.
Best choice is Asfbin. Since Version 1.5 it can even cut on non-keyframe positions, reencoding only the small part between cut and next keyframe. So the rest is not reencoded (unlike in moviemaker or other tools), so it is fast and preserves quality. it is a command line tool, though. If you need a GUI for asfbin, try Cut Assistant.
Important: For cuts on non keyframe positions you need the command line option "-rkf". NOTE: if you try -rkf and asfbin gives you this error: "Decompression error: VCM decoding driver is not available", the you must install the VCM driver from here:
http://www.microsoft.com/windows/windowsmedia/de/9series/codecs/vcm.aspx
You are in breach of the forum rules and are being issued with a formal warning. Please stop dig up old topics. A few was okey but not 20393209.
/ Moderator Baldrick
Edit/cut MPEG2 TS
By jon222 in forum Newbie / General discussionsReplies: 10Last Post: 11th May 2014, 15:30 -
Buy Which camera to edit with Final cut pro with no file conversion
By rossangelo in forum MacReplies: 4Last Post: 7th Apr 2011, 17:24 -
Query - How do i edit my Vado HD file in Final cut Pro 7
By vansep in forum MacReplies: 2Last Post: 10th Oct 2010, 12:52 -
Is there a way to edit (cut) an iTunes DRM video file?
By jimdagys in forum Newbie / General discussionsReplies: 4Last Post: 5th Nov 2008, 08:05 -
how to cut a wmv file
By stranzer in forum Video ConversionReplies: 5Last Post: 22nd Jun 2008, 11:26
