  1. I am trying to configure the TV Guide function. For the last 12-15hrs it has been going through and randomly clicking through all the channels any ideas as to why this is happening? Thanks!
  2. Randomly clicking through the channels? It should be going through them sequentially. It does that while searching for the channel that carries the EPG information.
  3. Its done that 3x. now it just randomly clicks channels here and there. Like Ill be watching 126 and all of the sudden my tv turns to 16 or 25, etc
  4. Member Leoslocks's Avatar
    May 2003
    That is wrong. Reset the machine and try setting up the system again. What you are watching should not randomly change.
    Are you sure the cat is not playing with the remote?
    To reset the system, hold the [] Stop button on the face of the recorder (just below the DVD door) and the Standby/On for several seconds.
  5. Sorry dont have a cat! Thanks for the input! I am close to giving up on this thing and sending it back! Thanks for the help! I get no TV Guide listenings and random channel changing...and here i was all psyched cuz I found a Pioneer DVR Cheap!
  6. What is with this thing? I give up! I thought maybe I had it working and I wakeup in the middle of the night to find I ordered Fantastic 4 on inPPV. I hate this thing man!
  7. You must have set it to control your cable box. That is a bad idea, IMO. If you tell the TV Guide setup that you have cable but no cable box, then it can use its own tuner, and it shouldn't bother you as much. It won't be able to change channels on the cable box that way, so you would have to program both the cable box and the DVR when you want to record a digital cable channel.
    Many people (myself included) have decided that the EPG is more trouble than it is worth. You don't really need it, and you can use the TIMER REC button on the remote to manually set your recordings just like you would with a VCR (only much better). If you want to disable the EPG, the information for doing that has already been posted in this thread.
