I just got the 110 to replace an A07. Installed it as master and updated to the latest firmware (1.37)
So here's the deal. I am getting discolleration of several shades on burned discs. I am using tai yuden -R X8 from Rima. I am using dvd decryptor to burn. I have tried burning at X6, X8, X12 with the number of shaded rings going down at each speed.
I am running an athelon 2400 with 512 megs of ram.
My A07 did not have this problem, nor my A08 that's in a different machine. Are other people having this problem? Is there a remedy?
See the dye surface images lower on the page at www.nomorecoasters.com
You've probably using Z-CLV media writing, and those are zonal burning rings, most likely. They are fine.Want my help? Ask here! (not via PM!)
Caopus ADVC 110 issue
By codeman in forum Capturing and VCRReplies: 2Last Post: 11th Dec 2011, 15:56 -
Macrovision and Canopus ADVC 110
By nikgelfi in forum Capturing and VCRReplies: 2Last Post: 13th Apr 2011, 17:09 -
Canopus ADVC 110 Possible problem?
By Drexter in forum Capturing and VCRReplies: 4Last Post: 20th Feb 2010, 22:10 -
Kworld ATSC 110 Problems
By Robert Simandl in forum DVB / IPTVReplies: 0Last Post: 2nd Sep 2007, 11:37 -
ADVC-110 and Vista
By shkinnybob in forum Capturing and VCRReplies: 3Last Post: 3rd Aug 2007, 17:23
