    Aug 2002
    hi can anyone hlep
    i want to use nero vision 4 to make a home dvd with menu etc, i know how to do all this but im puzzled, i downloaded the nero vision template package the other day and it has some great little video clips in it, for the menu etc, but they are in mp4 format and no matter what i try the program refuses to use them, can anyone tell me what else they may be used for if not for this purpose or how i can convert them so i can use them.
    cheers pete
  2. Member Krispy Kritter's Avatar
    Jul 2003
    St Louis, MO USA
    I've never used it, but I would expect you should be able to use everything the template pack. Have you tried looking in the guides section on how to use Nero Vision?
    Google is your Friend
    Aug 2002
    thanks, but still no joy, guess i will just delete them and then i wont keep at them
    Feb 2004
    Australia
    Divxtodvd will convert nero's mp4's into dvd format , but if they are small item's consider using Super or Mp4Cam2AVI to convert them .
    Was working on nero's mp4 the otherday and Mp4Cam2AVI reported frozen block's ... even though it converted it , there were audio issue's .
    Super , kept going and going , and on ... that time line thing went about 28 time's before it completed , and still audio issue's .
    Divxtodvd done well , second fastest in conversion , but the audio start's about 5 second's after the video ... easy to fix that later ...
    Use the freeversion ... the other place's "trial version - www.?????.com" crap on the top of your file ...
  5. VH Veteran jimmalenko's Avatar
    Aug 2003
    Down under
    Not if you buy it or are a Beta Tester it doesn't
    If in doubt, Google it.
