  1. Member waheed's Avatar
    Jul 2003
    Manchester, UK
    Im using Firefox 1.5 (latest version) and am having problems with the proxy settings (long story, to do with Terminator 2 watching HD version).
    Anyway, I want the option to be to directly connect to the internet:
    However, everytime I try to set this and press OK and restart Firefox, it keeps going to this option:
    How can I Prevent Firefox from doing this. Ive tried clearing all cookies, Cache , history etc..
    Internet Explorer works well and is set correctly but not Firefox.
    Uninstalling and Reinstalling doesn't work. Just tried that.
    Any ideas. Thanks.
  2. Member waheed's Avatar
    Jul 2003
    Manchester, UK
    Problem solved
    What I did was uninstall Firefox, delete the folder from Program Files and also delete the folder from C:\Documents and Settings\{USER}\Application Data and the Mozilla folder. It wipes everything.
