  1. I have an (old, 1989) VCR that obviously needs a change of head drum after some years of high quality delivery of VHS signals.
    I have found a new head at a reasonable ($30) price but the question is if I will be able to change it myself. Will it need special calibration that can only be done by a pro or can I sort things out myself with a great deal of patience?
    Anyone?
  2. Member Cornucopia's Avatar
    No, you will not be able to do it by yourself. That requires special installation & calibration tools, thorough knowledge of azimuth adjustment etc., service manuals, and more. Don't do it alone, use a pro.
  3. So it will require more than a screwdriver?
    Aug 2003
    bournemouth
    You will need to recalibrate the head. this can be quite tricky as the rf coming off the drum assembly has to be balanced and tuned for the 2 heads that provide the off tape signal.
    Barrybear
  5. Member mats.hogberg's Avatar
    Jul 2002
    Sweden (PAL)
    Don't think even a double Long Island Ice Tea will help...
    /Mats
  6. Hej, Mats.
    Det var synd.
  7. Member mats.hogberg's Avatar
    Jul 2002
    Sweden (PAL)
    Just pulling your leg - don't know zip about VCR's. But it sounds like a delicate and scary task - as everything analog !
    /Mats
    Mar 2002
    Toronto, Canada
    The actual physical replacement of the head is not the hard part, the alignment is. The tools one would need to do an alignment include:
    -dual trace oscilloscope
    -digital multi-meter
    -pattern generator
    -frequency counter
    -alignment tape
    -blank tape
    -colour TV
    -standard repair tools
    You would also need the specification sheet for the unit.
    Honestly, you're better off having a shop do it for you since it will be faster and easer than doing it yourself. While I've worked on VCR's, I wouldn't do a head replacement myself even though I do have access to the tools required. It's not my forté, and just not worth the trouble if I screw it up.
    Regards,
    Savant
