  1. OK, I've got some show I want to capture from VHS, but the final product I want them to be in is VCD. However I want to use filters in VirtualDub to clean the video up, then encode in TMPGEnc. I believe I can do this one of two ways:
    1) Capture to huffy, filter and re-encode to whatever, then encode in TMPGEnc
    2) Caputre to huffy, use AVISynth to serve to TMPGEnc
    I definatly won't do number 1, as that requires 3 different compression and makes the video look like crap. Number 2 however, I can't use all VirtualDub filters.
    I would capture to MPEG straight away, but as I said, I want to use Vdub filters (namely: deflicker, delogo, ACDsee and temporal smoother).
    Any suggestions how I could achive my aim?? Shall I capture a different way??? And I guess, using filters while capturing is a bad idea???
    cofferscuffs
  2. Doh! I've finally worked out how to use VirtualDub's frame server: http://www.vcdhelp.com/virtualdubframeserve.htm Ignore this post
