When I try to stream an MPEG2 clip from 4 VOBs pulled with MacTheRipper I get an odd error code that says "can't find the last audio sample" and I'm left with "OK" as my only choice and it quits. I tried it with another rip and it worked beautifully. It made a single MPEG2 clip from 4 VOBs very quickly. I'm rather new at this so if it is something dumb...be patient with me! I'm learning. The total file is 1:46:00 or so and is 3.91GB.
MacTheRipper 2.6.6
MPEG Streamclip 1.5.1
Mac MDD DP 1.0Gz
1.75 GB RAM
Anything else you need to know?
Thanks to all.
Does it ask you to fix any time code breaks?
could be a timing issue, thinks video is longer
than it should be, and thus is looking for more audio...?
a stretch i know....
"Everyone has to learn, so that they can one day teach."
When I'm not here, Where can I be found?
Urban Mac User -
Yes, it did. I tried it with the timecode fix and without. Neither worked. I tried it with another set of VOBs and it made a single MPEG2 file in about 12 minutes. It's a great program. Really fast. Not sure what to try next...
MPEG Streamclip: "Audio Decoding Error"
By addresstom in forum AudioReplies: 3Last Post: 30th Aug 2011, 10:12 -
No audio when saving .MPEG file from VOB stream using MPEG Streamclip?
By Bix in forum MacReplies: 3Last Post: 25th Jul 2010, 17:12 -
Mpeg Streamclip Problem (VOB files twitch)
By Keys in forum MacReplies: 2Last Post: 10th Aug 2009, 12:39 -
Write error problem with mpeg streamclip
By mattcourage in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 0Last Post: 8th Nov 2008, 10:57 -
mpeg streamclip quicktime alt problem
By m_shel in forum EditingReplies: 2Last Post: 11th Feb 2008, 23:14
