When I try to bring up task manager by clicking on ctl-alt-del a message pops up and says "Task Manager has been disabled by your administrator"
I tried clicking on taskmgr.exe in the system32 folder and get the same message.
How do I get it back? thanks
are you the admin? is this your own computer or a workplace computer?
To isogonic
Thanks for your quick reply. I found the answer on Google. -
Posting a link to the answer would be helpfull for all.Originally Posted by mysts
http://windowsxp.mvps.org/Taskmanager_error.htm
JSB -
To bring back your disabled Task Manager you require Task Manager Fix tool, available for FREE.
Task Manager strangeness... (XP Home, SP2)
By Xylob the Destroyer in forum ComputerReplies: 6Last Post: 17th Jan 2016, 09:09 -
iexplore/task manager problem
By mysts in forum ComputerReplies: 2Last Post: 6th Jul 2009, 23:24 -
Task Manager has disappeared
By mysts in forum ComputerReplies: 12Last Post: 6th Apr 2008, 08:51 -
Task Manager -- items which can be safe to remove without it rebooting.
By vhelp in forum ComputerReplies: 14Last Post: 1st Apr 2008, 11:49 -
what tool for this task?
By pheldd in forum Authoring (DVD)Replies: 7Last Post: 5th May 2007, 20:58
