  1. I know some people are able to edit Divx in Vegas but it's not working for me.
    So I've decided to convert the files to something that Vegas can handle better. I tried using VirtualDub to convert to some other AVI formats but it would take several hours just to convert a 30 minute file.
    What is the fastest way to convert Divx to a Vegas-friendly format?
    frameserve it from virtualdub or avisynth to vegas? if it doesn't open frameserved files try the vfapi reader.
  3. I've never cared much for frame-serving. I would only use it if there was no other way to do a particular job.
    It looks like converting to MJPEG would be quite fast.
  4. Originally Posted by sync
    What Happend?What didnt work?
    I never have problems Editing Divx Xvid. Did you try this? https://www.videohelp.com/forum/viewtopic.php?p=1291964#1291964
    What format did you convert to?
    Try Uncompressed takes only Minutes,If not somthing is wrong with your setup.
  5. I saw that and didn't understand how you uninstall the xvid codec.
    I didn't try Uncompressed because it takes 42GB for a 30 minute video. It looks like MJPEG at a high quality setting will be just as fast at one tenth the size.[/quote]
  6. To uninstall the XVID codec just go to add remove programs click uninstall/remove.
  7. Originally Posted by canadateck
    When I read about uninstalling xvid yesterday I only had a Divx codec to uninstall. There was no xvid codec. Today I upgraded to Divx 6. I thought I better check before replying. Well, there was an xvid codec and after uninstalling it, I can now see the video track in Vegas for divx files.
    Thanks!
  8. I may still end up converting divx files. I can see that Vegas is struggling with the divx format.
