Hi,
I have an mkv file whit 2 audio and a subtitle stream (of course also a video stream). When i play the file in Windows Media Player Classic it duration is 00:24:20 Min. When i open it up in MKVEGUI (MKVExtract) I only can see 00:07:11 min. In VirtualDubMod it's the same. I want to extra't all of the streams to seperate file for DVD Authoring but i can't seem to find the problem. The second episode is right 24 min in WMPC and 24 In VirtualDubMod.
I think the first file is "broken". But i have seen in on my computer and it does not give any error. Is there a way to fix this problem?
Results 1 to 15 of 15
tried mencoder? and save as avi, https://forum.videohelp.com/viewtopic.php?t=268844&highlight=mencoder
or an allinone mkv to dvd tool like avi2dvd. -
Tried mencoder did not work either. 7:11 min.
Tried VSO DivxToDVD did not work either (video resize to somethin like 500x10. -
Then I'd suspect the file is corrupted after all. MPlayerC is known to skip some errors.
Ok i saw when i load the file into VirtualDubMod there is 79134 Kb Parsed. (Parsing Matroske File) Then he tells there is a subtitle overlap (this is whit evry file)
When i look into the stream list i see the 3 (2 Audio, 1 SSa Subtitle) What i noticed is that the subtitle is longer dan 7:11 its 7:20. Mabye the subtitle in this file is getting in the way of parsing? -
Ok maybe i'm crazy now but i need the file to be demuxed. When you play any video can i capture it back. Like when i play the file the video of it is capture at the same moment to avi. I know i can capture the audio but i must play the file 2 times for english audio and again for japanese audio. Now another thing is the Subtitle. How could i get that back.
I could use fddshow to put the subtitle in the avi (when i capture it from my screen) the whit another kind of program (if somethin even exist) extract the subtitle out of it. The mux the mkv back?
Someone could tell me these programs exist? -
Same problem here.
I have 2 MKV files and if you demux/convert them it stops somewhere in the middle.
Both play ok im Windows Mediaplayer.
Video in the MKV is h.264
2 Soundtracks with A_AAC
and Subtitels
Anybody any idea?
I have tried: AlltoAVI, MKVExtractGui and VirtualDub - none worked for me
Problem with demuxing .ts file
By iXed in forum DVB / IPTVReplies: 5Last Post: 8th Aug 2010, 09:14 -
MKV Demuxing Problems
By Justin123 in forum Video ConversionReplies: 2Last Post: 10th Jul 2010, 01:33 -
Problem demuxing bluray mkv
By kadyn67 in forum Blu-ray RippingReplies: 0Last Post: 1st Jun 2010, 18:31 -
Demuxing mkv file for DVDlab
By harshest in forum Video ConversionReplies: 4Last Post: 22nd Mar 2008, 17:51 -
problem in demuxing mkv files
By noskid21 in forum EditingReplies: 2Last Post: 13th Aug 2007, 12:12
