Hi,
I have a lot of DVD concerts that I would like to play in my car. The head units does not recognize the backups that I have which has a VIDEO_TS folder. However, I have some concerts that is 1 layer and using DVDecrypter extracting to .iso and then using the same program to write the .iso file, will play on these head units like the JVC 5100.
I would like the concerts with 2 layers to be converted to .iso format so I can, hopefully play it on a car head unit.
Any suggestions or anybody have experience in playing 2 layer DVD's (backed up not the original) in any car head unit (Alpine, Pioneer, JVC or whateve is out there)?
Any help will be much appreciated.![]()
WinXP SP1, Epson R200 and Pioneer A107
Use dvd decrypter in File mode and use DVD Rebuilder to shrink the DVD to DVD5. There won't be any noticable change in quality this way and they will play fine.
Using DVD Decrypter should I use .ISO or .IFO file !
By augustya in forum DVD RippingReplies: 21Last Post: 29th Mar 2012, 12:44 -
Tool recommend for *.avi ---> DVD(iso) and ripping a DVD to *.iso file?
By pxstein in forum Authoring (DVD)Replies: 4Last Post: 11th Jan 2011, 16:51 -
DVD Decrypter to ISO file - missing
By mkr10001 in forum DVD RippingReplies: 4Last Post: 5th Jan 2011, 18:55 -
Burning ISO file to DVD
By hcs in forum DVD RippingReplies: 5Last Post: 2nd Feb 2008, 14:34 -
Can't burn .iso image file onto the DVD+R
By BabaKali in forum Newbie / General discussionsReplies: 12Last Post: 26th Sep 2007, 06:44
