Does anyone know (or used) a DVD authoring program or (and) DVD
burning program that will let me transcode an MPEG2 file in 1.85:1 or 2.35:1
format and burn it also in that ratio?
Ram
It has nothing to do with 'authoring' nor burning. It is ony a matter of encoding. DVD ony allows for 16:9 or 4:3 aspect ratios. Everything else needs letterboxing.
More or less all authoring/burning programs as well as encoders support anamorphic encoding. It is only your problem to do it correctly.GUI for dvdauthor:
https://www.videohelp.com/~gfd/ -
You need to encode it correctly, then author it as 16:9. Burning has nothing to do with aspect ratios.
If you material is < 1.78 it should be displayed 4:3, possibly with letterboxing. If it is > 1.78 then it can be displayed 16:9, with letterboxing. If it is 1.78 then you can just encode it 16:9 without letterboxing.
What is your source material (format, resolution etc.) ?
What is your encoder ?
If you have avi and want it simple, DivxtoDVD is easy, can do 16:9, and the payware version even burns for you.Read my blog here.
Is it possible to re-edit a non-anamorphic dvd to anamorphic?
By Beautiful Alone in forum DVD RippingReplies: 45Last Post: 22nd Sep 2011, 10:00 -
DVD Lab Pro Menu Resolutions
By Anonymous344 in forum Authoring (DVD)Replies: 0Last Post: 6th Dec 2010, 18:11 -
Best way to convert 4:3/non-anamorphic DVDs to 16:9 anamorphic. HELP!!
By CoachSerpico in forum Video ConversionReplies: 9Last Post: 11th Feb 2010, 16:46 -
Issues Authoring DVD with different resolutions
By Smack2k in forum Authoring (DVD)Replies: 3Last Post: 11th Nov 2009, 03:24 -
DVD screen capture resolutions???
By cabala420 in forum Newbie / General discussionsReplies: 4Last Post: 25th Apr 2008, 12:28
