Hello,
I have been trying to copy a DVD using DVD shrink. When I try to open the DVD it analises to 82% then says
' DVD Shrink encountered an error and cannot continue. Failed to read file "D:\" '
I know this DVD works in my dvd player and I have burnt discs using DVD Shrink in the past. WHat could be the problem.
I have also tried in DVD Decrypter but although it will decrypt the file, I am unable to burn it in any programs.
Hope someone can help.
Closed Thread
Just another point, When I try to burn the decrypted files using Nero Recode, I get the following message.
"An internal error occured. A VOBU address is out of bound. This may be caused by an invalid DVD navigation structure. "
How can I sort this out and manage to burn the DVD?
You should have looked at this: https://forum.videohelp.com/viewtopic.php?t=283172
please do not cross post.
https://forum.videohelp.com/viewtopic.php?t=289335&highlight=
Issues getting DVD Shrink to work under Win7-64bit
By Djinn987 in forum DVD RippingReplies: 11Last Post: 30th Oct 2012, 17:44 -
I Can't Get DVD Shrink To Work. Strange Behavior Problem.
By V Bot in forum DVD RippingReplies: 1Last Post: 2nd Jun 2011, 00:55 -
How do I get ImgBurn to work with Shrink?
By Jonathan in forum DVD RippingReplies: 8Last Post: 27th Dec 2010, 16:09 -
Hello My dvd shrink 3.2 does not work anymore
By Seekyr in forum Newbie / General discussionsReplies: 1Last Post: 26th Apr 2009, 20:14 -
Can't remove region restriction using DVD Shrink. Work-arounds?
By csloane@nwnexus.com in forum Newbie / General discussionsReplies: 2Last Post: 7th Apr 2008, 17:04
