I have been using Mushkin Value RAM for about 7 months. Recently my PC has been rebooting itself, having stop errors, and freezing up, I traced it down to bad RAM with MEMtest86, which found over 200,000 errors. My question is, which brand of RAM do you folks use. I do not overclock and am not a millionare, just looking for good quality RAM to finish my christmas videos without using words that my kids shouldn't hear. Thanks a bunch in advanced.
Results 1 to 9 of 9
Crucial is what I've always used and I've never had problems. I'd say its generally considered one of the higher quality RAM manufacturers.
Does the memory have a lifetime warranty?Originally Posted by Weapon
Corsair and Kingston are usually pretty good brands to buy. Just make sure you buy memory with a lifetime warranty. -
If you still have the sales receipt for the memory, check with Mushkin to see if they will replace it.
But if you get a different brand, make sure it has a lifetime warranty.
I've used Corsair Value Select DDR RAM in several computers with no problems. It's a good inexpensive brand of memory if you aren't overclocking. And it is lifetime guaranteed. -
And make sure you did not physically damage the RAM by static electricity and that sort of stuff.
nothing wrong with mushkin memory. kingston is another one to consider
http://www.mushkin.com/doc/customerservice/warranty.asp -
Thanks for the link. I will try an RMA, but it has been 7 months and I don't have the sales receipt from Newegg. We'll see how it goes.Originally Posted by isogonic
And I'm certain I have'nt damaged it with static electricity, Im always grounded when I open up the box. -
if you bought it from newrgg, they have the reciept inyour acct. mushkin will honor it.
my current preference is patriot. i can't tell you jack about ram, but i'm believing it is faster and more stable than the kingston/crucial/geil/corsair and other lesser names i've used.... -
I use Corsair and Kingston memory almost exclusively in any system building project. I've gotten too many bad Mushkin or PNY memory modules so I don't recommend either of those. Another good memory module if you're on a budget is one called value. As it's name implies it's usually one of the cheapest and it has good reliability, if you don't plan to overclock. If you have value ram and plan to overclock I recommend memory coolers because the value brand ram becomes unstable rather quickly in OC environments.
Wanted: good/used DDR memory
By DirtBikeMike in forum ComputerReplies: 3Last Post: 9th Feb 2010, 13:54 -
DDR and DDR2
By Jomapil in forum ComputerReplies: 3Last Post: 18th Dec 2008, 07:50 -
DDR vs DDR2
By CSULB71 in forum ComputerReplies: 2Last Post: 1st Jun 2008, 14:54 -
DDR versue DDR2 Question
By SCDVD in forum ComputerReplies: 8Last Post: 11th Oct 2007, 13:50 -
Question about refreshing DDR RAM for video application.
By SingSing in forum Video ConversionReplies: 7Last Post: 13th Aug 2007, 11:41
