help guys.
Guys I find 2 prog in my pc 1- lotto logic professinal 2-sam reset. I don’t know where they come from and when I try to delete. in add or remove I go this message.![]()
Couldn’t not open (c:/program files/ lotto logic professional /ST5unst.log.) and the second one is.
(c:/program files/Sam reset /ST6unst.log
when i do search nothing come and both they are in add or remove side.
any help appreciated.
ahmed tabit
The first program seems to be for generating lottery numbers. The second looks like something that may be resetting your Security Accounts Manager.
This looks like a trojan/virus problem.
I would try booting in 'safe mode'. This usually keeps program drivers from loading. Here is some info on that. http://service1.symantec.com/SUPPORT/tsgeninfo.nsf/docid/2001052409420406?OpenDocument...rc=sec_doc_nam
Once in safe mode, try uninstalling the programs again.
If they are trojans, you might go to TrendMicro and do a online scan. http://housecall.trendmicro.com/
And if you don't have them, I would suggest getting some antivirus software and some antitrojan software. I use the freeware programs AVG for antivirus and Spybot S&D for trojans. -
@redwudz
thanks mate for you are quick answer i sorted mate with this prog .
(advnanced uninstaller) is good tool.
ahmed tabit
Help with ripping
By kuasd in forum Video ConversionReplies: 5Last Post: 26th Oct 2011, 07:57 -
Beauty&Beast Blu-Ray Ripping Loses 3-Dimensionality after ripping
By KostaRae in forum Blu-ray RippingReplies: 4Last Post: 22nd Mar 2011, 04:50 -
New, have some ripping Q's
By RooD in forum Blu-ray RippingReplies: 3Last Post: 10th Dec 2010, 10:57 -
A ripping software that you can pick what you're ripping?
By twells22 in forum Newbie / General discussionsReplies: 4Last Post: 6th Feb 2008, 09:22 -
ripping help
By merkzilla in forum Newbie / General discussionsReplies: 1Last Post: 13th Jan 2008, 21:38
