I have some divx files (yes, that is the extension as well).
As I have have the latest xvid, and recall an incompatability between the two competing codecs, I'm looking to convert the divx files to xvid.
Odd to be sure, but, I want to keep xvid.
Ideas?
Results 1 to 18 of 18
"Failed to create instance of DIVX Decoder Filter".. etc
Says the above with either .avi or .divx extension. Though. gspot does indicate codecs are installed.
I uninstalled xvid 1.1 (clean) and resinstalled, to no avail (not surprising).
/edit
hmm, I wonder if the problem is v1.1 itself. As now, gspot will not render files with avi extension either, with same error. Will uninstall 1.1 and retry 1.0
Actually, I'm wondering if an issue isn't with gspot now. With xvid uninstalled (and its leftover .ax removed) gspot is still saying codec is installed (after reboot) and yet, avi's won't play outside of VLC.
This is a bugger of an issue. -
I uninstalled xvid 1.1 (clean) and resinstalled, to no avail (not surprising). <<<Originally Posted by kschang
Perhaps we were cross posting. ;D -
Hmmm... You sure ou got the BINARY of XVID? My file says
XviD-1.1.0-30122005 _Final Release_
And I got it from http://www.koepi.org/ -
im gonna guess that the file itself is corrupt somehow...maybe you can go old school and try divfix on it? and does it open in say virtualdub? If so you can probably just rebuild the file by going video direct stream copy and audio direct stream copy.....thats if there's an issue with the actual file header, that oughtta fix it...if its within the video stream itself, it may or may not even be fixable........give it a shot and see how it goes.
Good call.Originally Posted by whitejremiah
Won't open in VirtualDub (see error in screen below).
However, DivFix shows no errors.
Note... both programs failed to recognize the files. I had to change the drop down menu to "All Files" for them to be seen.
kschang
(Yes, I'm aware that VLC has its own codecs, which is why I used it, and mentioned that the files actually play).
/edit... screen didn't post.
Scroll up a bit m8, and you'll see...Originally Posted by celtic_druid
However, what I did hadn't tried, is renaming the extensions to avi, after installing FFDshow.. and sure enough... they now play!FYI, I uninstalled that, and installed latest FFDShow... same issue.
So, thanks for that post, reminded me to try that again with the new codec!
/me is a happy camper again.
Thanks to all involved.
My DivX DVD Player can't play my avi DivX/xvid video
By Baldrick in forum DVD & Blu-ray PlayersReplies: 32Last Post: 6th Mar 2015, 10:11 -
HD video to avi divx/xvid
By babeflover in forum Video ConversionReplies: 4Last Post: 14th Aug 2011, 13:28 -
Best MKV to Avi=divx/xvid
By s-toon in forum Video ConversionReplies: 9Last Post: 9th Aug 2011, 16:50 -
DVD to AVI (done) to Divx or xvid
By Grumpy_one in forum DVD RippingReplies: 3Last Post: 16th Mar 2009, 18:28 -
Best DVD to DivX / Xvid avi
By spidey in forum DVD RippingReplies: 6Last Post: 3rd Jul 2008, 15:20
