I've used the patch method with IfoEdit a few times but lately it hasnt been working. Has anyone used a program that does it for them?
Have you tried searching ? This is probably close to the most popular question, and there are a dozen posts a week covering it. I'll start you off - search for DGPulldown posts and go from there.
For best results, buy a cheap, multi-format DVD player and don't waste your time converting.Read my blog here.
Use the seaaaaaaaaaaaaaaarch, type in "pal to ntsc" (with the ").
and what exactly is happening when you use the patch method? doesn't work on the standalone dvd player at all? strange playback?? -
Y E S I did Search!
I would like to know what people have trided that do work.
Thank you very much! -
It usually works for me. You can try searching the forums, or search the guides, or search the tools section. Each will find you different angles on the same issues.
Tools is probably the easiest to start with. You can search by conversion type, get a list of tools to assit, see what others think of those tools, and get a pretty good list of guides for using them, all in one go.Read my blog here.
AVI2DVD works well, it automates the rather lengthy process of converting frame-rates, adjusting audio speed & reencoding etc - which is probably the "correct" way of doing this. Although, DGPulldown is another method I haven't tried, and keeps the original duration (no slowing down or speeding up). I'm not sure how "universally compatible" this is, though. I believe the IfoEdit "patch method" you tried is not 100% compliant, might work for you but not the next person.
Pls help! Best way to convert NTSC VHS (captured using PAL VCR) to NTSC DVD
By rairjordan in forum Capturing and VCRReplies: 33Last Post: 28th Nov 2013, 12:33 -
Convert PAL to NTSC?
By killerteengohan in forum Video ConversionReplies: 32Last Post: 7th Feb 2012, 12:33 -
How to Convert NTSC to PAL
By Gusto747 in forum Video ConversionReplies: 14Last Post: 19th Aug 2010, 20:52 -
By rock.freak667 in forum DVD RippingReplies: 8Last Post: 21st Jul 2009, 09:16 -
How to convert PAL DV to NTSC (I ONLY have NTSC DV camcorder to play with)
By inspiron2 in forum Video ConversionReplies: 4Last Post: 7th Jul 2008, 22:45
