hi there...
well I have a dvd movie with subtitle..so the question is:
how can I extract the subtitle in this dvd and see the beginning time and the ending time of each sentence and the sentence it self..
so I can translate to another language just by traslating the sentence it self and using the same timing that the original one use...
NOTEI'm using DVDLab Pro to author my dvds and fot subtitling)..
THANKS IN ADVANCE..
CAESAR
you rip to text subtitles with subrip, https://forum.videohelp.com/viewtopic.php?t=267416
You'll also want to check out subtitle workshop I think. This helps checking for prob., & if you increase the number of characters per line, you might need to add lines so all are displayed on TV -- it'll help there too.
Extract only the timings of Japanese subtitles, to make a translated fansub
By yojimbo2000 in forum SubtitleReplies: 4Last Post: 11th Aug 2010, 12:26 -
Replace subtitle timings
By Abas-Avara in forum SubtitleReplies: 3Last Post: 19th Jun 2010, 08:32 -
MKV to AVI program, hardsubbing program, adding subtitle to DVD Flick
By projecttemp in forum Video ConversionReplies: 1Last Post: 21st Sep 2009, 09:42 -
Overlapping subtitle timings for multiple entries onscreen?
By viewpoint in forum SubtitleReplies: 1Last Post: 30th Aug 2009, 21:22 -
How to take the timings from one subtitle and put them into another?
By acid_burn in forum SubtitleReplies: 0Last Post: 8th Jul 2007, 12:11
I'm using
