Hi all. I recently burned a DL disc for the first so I'm not sure about some things. Everything went ok except when i ran dvdpro and check the disc for errors i found 17 errors in one sector that was bad. It was:
1. Error - LBA = 00248950h
2. Error - LBA = 00248951h
3. Error - LBA = 00248952h
4. Error - LBA = 00248953h
5. Error - LBA = 0024895bh
6. Error - LBA = 0024895ch
7. Error - LBA = 00248984h
8. Error - LBA = 00248989h
9. Error - LBA = 0024898ah
10. Error - LBA = 0024898bh
11. Error - LBA = 0024898ch
12. Error - LBA = 002489c3h
13. Error - LBA = 002489c4h
14. Error - LBA = 002489c5h
15. Error - LBA = 002489c6h
16. Error - LBA = 002489ceh
17. Error - LBA = 002489cfh
My question is can someone tell me where on the disc or how many minutes in the error is. I have a series of tv shows and previews on the disc and if the shows aren't affected by the error and the previews are then i don't care. But if the show is will i be able to just skip over that part when watching it. Basically I don't want to use this disc as a coaster.
Hope i didn't confuse anyone.
thanks
bruce
I assume you mean DVD Info Pro - how far through the disk did the colours change in the display. You can get a rough idea of the location from this. It starts on layer one, at the centre, and works its way out to the layer break at the outer edge, then comes back toward the centre on layer two.
At a guess, I would say somewhere towards the end of layer one/start of layer two, only because the outer edge is where most issues occur.Read my blog here.
here is the screen i got from DVDInfoPro.
Only one box has a red dot. The rest are green. Also sorry about the banners in the middle.
You know you have just used ctrl-printscreen instead of hypersnap ?
It's a small error, but probably will cause breakup on playback. If youa re lucky it won't freeze the player.
Personally, I'd put my drink on this one and burn a new one.Read my blog here.
DVD FLICK, Start-up Error Msg-Unable to created txt file. Last DLL error: 5
By jacknscoob in forum Authoring (DVD)Replies: 5Last Post: 4th Mar 2012, 08:58 -
DVD Shrink Error: Programing Error, exception occurred
By lapetite_66 in forum DVD RippingReplies: 5Last Post: 2nd Jun 2010, 15:59 -
BD REbuilder ERRor - Error in attempt to extract audio/subs.
By ajhansen91 in forum Blu-ray RippingReplies: 1Last Post: 26th Mar 2009, 14:39 -
Get many error messages, AviSynth error message and meGUI error
By MKVcrazy in forum Video ConversionReplies: 0Last Post: 25th Aug 2007, 16:41
